Hello! I purchased RCD300 plus to my Santana MT. However, It did not reflect the time in my instrument cluster. How do i adjust it? Thank you!
1,Press the left knob of the unit to turn on the radio.
2,Turn the left knob to the lowest volume until the mute .
Click the left knob twice. It is equivalent to turning the radio off and on quickly. At this time, 76 ℃ will appear in the upper right corner of the screen.
Turn the left knob to increase the volume to any value between 1 and 30. Quickly press the left knob twice. At this point, you will find. The value of the minute is increased by 1. You can click twice continuously and it will increase gradually.
The above method is how to increase the minutes.
3,Turn the left knob to the lowest volume until the mute .
Click the left knob four times. It is equivalent to turning the radio off and on twice quickly. At this time, -46 ℃ will appear in the upper right corner of the screen.
Turn the left knob to increase the volume to any value between 1 and 30. Quickly press the left knob twice, At this point, you will find. The value of the minute is Decreased by 1. You can click twice continuously and it will decrease gradually.
The above method is how to decrease the minutes.
4, Turn the left knob to the lowest volume until the mute .
Click the left knob Six Times. It is equivalent to turning the radio off and on Three times quickly. At this time, 74 ℃ will appear in the upper right corner of the screen.
The above method is how to increase the hours.
5, Turn the left knob to the lowest volume until the mute .
Click the left knob eight Times. It is equivalent to turning the radio off and on Three times quickly. At this time, -44 ℃ will appear in the upper right corner of the screen.
The above method is how to decrease the hours.
Be careful not to power down your unit or you will repeat the above time setting steps.
