Hello, if I purchase 187B RCD 330 with rear USB, can you code it to work with 2008 Passat dynaudio?
Hello
Yes. I can changed code for Dynaudio. Please note that you have Dynaudio when placing an order.
In addition, your car has battery drainage problems, you also need to buy a CANBUS simulator or a new gateway.
VW original Gateway CANBUS slove Battery Drain 7N0 907 530 AG/AM/AR
