Hello, I\’m thinking to order this camera from your site for my 2009 Golf MK6 with RCD330 Noname 187B head unit but I still have two questions if you can answer? The first one is about Canbus and guidelines features. Do I need VCDS and ODB to enable any codes on my car? is there any way to find out the reverse camera is enabled on my car without VCDS? The second one does it come with a warranty or return policy if there is any issue with the camera? Thanks
If the OPS image is displayed on the screen when you are reversing, it means that you have turned off the backup camera function. You must activate the backup camera function of the head unit through VCDS or OBD11, so that your unit can switch to the reversing image screen when reversing. You cannot activate or deactivate the camera by upgrading the firmware or other way.
The backup camera has a warranty policy. If there is any failure, I will be responsible for replacing it. But I must tell you that there are a lot of Flip badge cameras that are very cheap, but I never sell them. I am also a fan of Volkswagen, and I don’t want to make some counter-conscience transactions just for more profit. Therefore, the cost of my product is higher than other similar products
