QA QuestionsCategory: Other Questionmy rcd330 187a It doesn't display temperature, temperature, and timing How do I operate it ?!
akram asked 1 month ago
akram replied 1 month ago
How do I operate it
ddren Staff answered 1 month ago
I don’t know if the unit you are using is desay 187a or no name 187a.
Usually there are two possibilities, do not show the temperature.
#1.If you install a decoder, It will cause the temperature display to be lost.
#2. There is a problem with your CANBUS communication, Causing the temperature data not to be received from the gateway.
