First, my Rcd 330 powers on with only a white screen, then finally comes on, but no steering wheel controls and no touchscreen controls, and no audio. It had been working for a few months perfectly fine before that.any idea?
I want to tell you that you must buy the real RCD330 plus. Now some products in the market are replicas, not from Tianbao company in China. If you compare the real RCD330 plus with the replica, you will find that although their internal structure is the same (RCD360 is a completely different internal structure). But if you look closely, it is still different, and the quality of the replica is not good. There are many units that break down after a period of use.
187F is artificially changed to 187F by some sellers in order to obtain higher profits. In fact, it is 187B or a copy of 187B. Some customers mistakenly think that 187F will be more advanced than 187B, this is just a trick. Don’t believe it. And after you change 187B to 187F, you will not be able to upgrade the firmware via USB.
So what you have to do is buy a real RCD330 plus.
