I have a 2012 VW Beetle with Fender Audio and RNS315 OEM Headunit. Is your RCD330 a straight replacement remove plug and play? No quad lock adapter required? Will I be able to use my steering controls with it?
You can replace your original unit with the RCD330plus directly, plug and play, no extra adapter required.
With every button on your multi-function steering wheel, you can still continue to control the RCD330plus.
But you have to note that your car has a fender sound system when you place the order, and I will change the code for you.
