- if you get package A with just rear usb for golf. what aux inputs will work? will the factory aux input work?
- also will the original MDI media-in port still be capable of charging a phone?
You can choose to install it on the outside of the armrest box, which requires you to choose package B. If you want to install it on the front of the shift, please choose package A.
If you want to install it inside the central armrest box, you need to dig the hole with a box cutter and choose Package B.
AUX is not change to the rear, so only the front panel AUX will work for you.
