Hola, es compatible con seat Alhambra 2013? algún problema con los envíos a España?
Very, very beautiful MPV. Unfortunately, I cannot get it in China.
You can directly replace your original unit with RCD330 plus, plug and play, there is no battery drain problem, you can also note when placing an order, you want to get the SEAT boot logo. I will change the firmware for you and update your unit.
