I have Mk5 Gti 2009. I use Android phone. I would like the rear USB option. Which model is this please? Are there any issues that I may encounter?
Thank you.
Phil
Hello, no problem, what you said is correct. You need to confirm whether your car has an eight-button multi-function steering wheel, and if so, you need to buy a simulator, otherwise the eight-button multi-function steering wheel can not control the RCD330 plus. If not, you don’t have to do anything.
