Hello, I was wondering if the included “1 PCS AV Camera Adapter(Gift)” will allow my factory backup camera to work with the RCD330? I have a 2014 Jetta Sportwagen TDI. Thanks!
Your original camera is an RGB format camera. That gift can’t solve your signal conversion problem. You can install an RGB to CVBS adapter, but this solution is not very stable and works unstable in some cars.
I recommend you to buy a brand new camera, which not only can get a better clear image than the adapter, but also supports dynamic parking lines. The installation difficulty of the adapter and the new camera is almost the same.
