QA QuestionsCategory: CANBUS & Gateway Questionrcd330-plus-2008-jetta-battery-drain-solution
Lucio Leon asked 5 years ago
Hello,I\’m planning on purchasing the Noname 187B with Rear USB AndroidAuto RCD330 Plus for my 2008 VW Jetta. I do NOT have MFSW or rear camera. If I don\’t want battery drain issues will I also need to purchase the $22 MFSW Control Canbus gateway Simulator RCD330 plus, or the $30 VW original Gateway CANBUS solve Battery Drain 7N0 907 530 AG/AM/AR ?Thank you
Yes.
You need to choose between the two. In order to solve your battery drainage problem, I recommend CANbus simulator, because it is easier to install.
