I want to swap the RNS510 unit in my 2015 VW Scirocco with a No-Name R330 plus unit with android auto and rear USB.
Are there other connections and adaptors i will need? I also have factory reversing camera and parking sensors and steering wheel controls that I need to work on the new RCD330 Plus. Can you please let me know what connections i will need for all the functions.
Your parking sensor can continue to work, and each button of your multi-function steering wheel can still directly control RCD330 plus. But your original backup camera cannot work directly for RCD330 plus. You have two options, use a brand new set of flip badge camera replaces the old one. Or, you install the RGB to CVBS adapter. The difference between the two solutions is that the new camera has higher resolution and supports dynamic parking lines. RGB adapter, the image definition is not as good as the new camera, and it only converts the RGB image of the original car.
The RGB adapter I sold is out of stock, and I can’t restock it for a while. If you want to choose RGB to CVBS, you can go to the AliExpress website to buy.
Flip badge camera Dynamic parking line Golf6/7 GTI Polo EOS Beetle PassatCC RCD330 plus
