Hi I have an golf 6 plus.
It has pdc, no rear cam and a multiwheel, it’s a car for German market. Do I need any extra adapters? Do I have to perform coding or will the device be coded(camera turned off)?
You can directly replace your original unit with the RCD330plus without buying any additional adapters.
You need to note when placing an order that de-activate the backup camera function. You also need to note that you need German firmware.
It is recommended that you select a module from the following links.
Noname 187B RCD330plus
2.Standard original unit + rear USB or + wireless carplay and wireless androidauto dongle 2 in 1
https://www.rcd330.com/product/rcd330g-plus-noname-187b/
