Hi there! I have a mk5 2008 r32. I would ideally like a rcd330, with the adapter to be able to use steering wheel buttons, and avoid battery drain. I do not want a rear camera, and do not want the unit to flash the rear camera warning while in reverse. What is my best option?
Thanks!
First, you need to buy a CANBUS simulator to solve your battery drainage and steering wheel control problems.
When you place an order, note that you need to deactivate the backup camera.
You can select a unit from the links below.
Noname 187B
