Hello, which RCD-330 do I need for a 2013 Jetta SEL with Fender Audio sound system? I want the rear USB as well as a back up camera added. Would there be any other programming on my end that I would have to do to make it work or is it plug and play?
Hello, You can directly replace your original unit with the RCD330plus, plug and play your car without battery drainage problems, and if you have a multi-function steering wheel, every button of your NFSW can control RCB330plus.
If you have a fender sound system and you need to , note that you have a block floor upgrade system and I will change the code for you.
https://www.rcd330.com/product/vw-passat-jetta2012-tiguan-dynamic-track-parking-line-handle-rear-view-camera-for-rcd330g-plus
https://www.rcd330.com/product/noname-187b-androidauto-rcd330-plus-rear-usb
If you have a fender sound system and you need to reorder, note that you have a block floor upgrade system and I will change the code for you.
