Hi Ddren,
I am interested in the Wireless CarPlay Unit + Noname 187B AndroidAuto RCD330 Plus + Rear USB. I have a some questions I am hoping you can help me out with?
I own a 2013 Volkswagen GTI. I hoping to use Apple Car Play with an IPhone 12. I would like to be able to use it wirelessly.
- How is it install process? Is it a plug and play? Are any technical soldering or anything like that involved?
- How is the wireless connection? Is the wireless connection generally stable and will not drop connection often?
- Which unit do you recommend I purchase?
- How long is the ship times?
Thank you,
Really appreciate the help!
Good morning.
Your car can be fitted with the RCD330 Plus. There is no battery drain problem and if you have an MFSW it will also work for the RCD330 Plus.
I can change the code of the radio to make it work better for the Dynaudio sound system. Your original clamshell camera is in RGB format, it cannot work directly for RCD330 plus. You have two solutions, one is to install an RGB to CVBS adapter, and the other is to purchase a new set of flip cameras with dynamic parking lines.
Flip badge camera Dynamic parking line Golf6/7 GTI Polo EOS Beetle PassatCC RCD330 plus
