Looking for best headunit for Manual Jetta 2012
Car has original screen with only Bluetooth capabilities
Looking to add CarPlay for iPhone and a backup camera
Can those purchased together?
You can simply replace your original unit with the RCD330plus, plug and play, no extra adapters required, and your car has no battery drain problems.
If your car has a fender sound system, you must note that your car has a fender sound system when you place an order, and I will change the code for you.
You can choose one from the links below.
RCD330 PLUS RCD340G Noname 187B For Jetta Golf Passart Tiguan
Noname 187B with Rear USB V3 AndroidAuto RCD330 Plus Jetta MK5 MK6 Passat Polo2013
Wireless CarPlay Dongle+ Noname 187B AndroidAuto RCD330 Plus + Rear USB V3.0
trunk switch camera
