QA QuestionsCategory: Head Unit Questionfender-audio-in-2014-passat-sel
Antoine asked 6 years ago
Hello, I was wondering which unit would work with the 2014 Passat SEL, which came with Fender audio and navigation head unit. Will the no name rca 330 187b with rear USB be a good match for this 2014 Passat SEL model? Will the antenna, rear video camera, Bluetooth and steering wheel controls work without any additional adapters? thanks in advance
Ddren Staff answered 6 years ago
Hi friend.
Your original unit is most likely RNS510 or RNS315. Yes. You can choose RCD330 plus Noname 187B with Rear USB, the link is as follows:
In order to make your fender audio work better, I need to modify coding of unit by VCDS. Do it like in the video. If your original unit is RNS510, then there is a Bluetooth module under your passenger seat, you need to disconnect plug of bluetooth module. Noname 187B comes with powerful Bluetooth function, its connection speed and function are more powerful than the original Bluetooth module. Your multi-function steering wheel can be directly supported without any adapters. You have no battery drain problems. RCD330 plus can be plug and play. If your car with the original backup camera, it is a RGB format camera, it can not work directly for RCD330 plus, if you want to keep this camera, you need to install an RGB to CVBS adapter, you can also give up the original camera, directly buy a dynamic parking The camera of the car line. The link is as follows. If you have other questions, you can also directly contact me on whatsapp
https://www.rcd330.com/product/vw-passat-jetta2012-tiguan-dynamic-track-parking-line-handle-rear-view-camera-for-rcd330g-plus/
