QA QuestionsCategory: Head Unit Questionpassat-b6-2010-with-rear-camera
Steef asked 5 years ago
I have a 2010 B6 passat with rear camera already installed, what would be the best model to use with Apple Carplay?
Hi friend.
Your original unit is most likely RNS510 or RNS315. Yes. You can choose RCD330 plus Noname 187B with Rear USB, the link is as follows:
Your car with the original backup camera, it is a RGB format camera, it can not work directly for RCD330 plus, if you want to keep this camera, you need to install an RGB to CVBS adapter, you can also give up the original camera, directly buy a dynamic parking The camera of the car line. The link is as follows.
https://www.rcd330.com/product/vw-passat-jetta2012-tiguan-dynamic-track-parking-line-handle-rear-view-camera-for-rcd330g-plus/
