Hello i have a Passat variant 2008 2.0 tdi 170cv highline. I want to know how head unit i have to install and what plugs to can use the bottons of the wheel the antena and the parkassist sensors. I want to install rear camera too.
https://ibb.co/mb4vG94
https://ibb.co/PT7twn8
Hello, first of all, your car can be equipped with RCD330 plus. Your multi-function steering wheel has 8 buttons, and this steering wheel does not directly control the RCD330 plus. So you have to install the CANBUS simulator.
You can select a unit from the link below.
1.Standard Original unit
RCD330 PLUS RCD340G Noname 187B For Jetta Golf Passart Tiguan
Noname 187B with Rear USB V3 AndroidAuto RCD330 Plus Jetta MK5 MK6 Passat Polo2013
Wireless CarPlay Dongle+ Noname 187B AndroidAuto RCD330 Plus + Rear USB V3.0
The trunk switch camera fits the Passat, if your car is a Passat CC you need to install the flip camera.
