I have a european Jetta from 2007.
What model of flip camera and radio would fit my car?
First of all, for Jetta, you can’t install a flip camera. You can only install the trunk switch camera.
Secondly, your car has a battery drainage issue, and you need to install a CANBUS simulator.
You can select the unit and camera from the following links, as well as the simulator. When placing an order, you must note that your car is a 2007 Jetta. So I can choose the right camera for you.
2.Standard original unit + rear USB or + wireless carplay dongle.
RCD330 PLUS RCD340G Noname 187B For Jetta Golf Passart Tiguan
Noname 187B with Rear USB V3 AndroidAuto RCD330 Plus Jetta MK5 MK6 Passat Polo2013
