Dual USB ports, keep Front USB, Add Rear USB port, Carplay , Android Auto.
VCDS errors when swiching from RNS315 to RCD330 Plus
Hi,
I recently installed my RCD 330 (Noname). It works great but when I do auto-test on VCDS I get many errors related to the old RNS315.
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
18-Aux. Heat -- Status: Cannot be reached 1100
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
6E-Ctrl Head Roof -- Status: Malfunction 0010
How can I fix it? I tried to remove from the Gateway list 2E and 37 modules but it's the same. Any help please? Thanks
If we can find a common time, I can log in to your laptop remotely to clear these error messages for you. You need to install the teamviewer software and log in to your laptop remotely. You can send me teamviewer control account and password via whatsapp.
Hi. My Vagcom cable is not a genuine unit so when I connect to internet the computer it could fail. Maybe it you explain what would you do I could do it. Is it necessary to physicaly uninstall the old bluetooth unit?
