CarPlay no nav audio
Hi 🙂
I have RCD330G (6RD 035 187B noname)
I have Dynaudio soundsystem programmed via VCDS as Skoda soundsystem
When using navigation (apple maps, google maps) I can't hear any navigation audio. I have tried different iPhone
Music dips slightly when navigation instruction is being read, during which i can turn the volume knob which says 'Navi (app)' on the volume slider.
But whatever I do there is never any audio for maps
Has anyone had this and know what might fix it?
Thanks!
tszmo has reacted to this post.
tszmo
Hi
What is your original head unit? RNS315 or RNS510 or RCD510 do you have a separate Bluetooth module, usually it is under the passenger seat, if there is, you need to unplug this module, it can really stop working, and then delete all Bluetooth in your phone For the successfully paired device, restore the factory settings of the head unit.
The old Bluetooth module will interfere with your call, including the work of carplay.
noogie has reacted to this post.
noogie
Original radio is RCD510, I just disconnected the Factory bluetooth unit and deleted all bluetooths from phone. I then went to Setup on radio and did factory settings, changed Language to EN(US) and sadly the carplay navigation audo is still missing - but the song quietens when a direction would be spoken.
When I first installed RCD330 directions worked - So maybe I broke it by switching to Skoda Soundsystem for Dynaudio in vcds?
Anything more I can try?
tszmo
Hey ddren - any other ideas?
I tried putting radio back to normal soundsystem with VCDS but still no nav audio.
I changed it back, my long coding is 1C020041010004
tszmo
I'm having the exact same issue. Golf R Mk6 with Dynaudio. Music volume dims ready for the nav audio to read out but nothing comes through. Nav audio on max.
Unit was coded to work with Dynaudio from purchase and all works fine - purely just the nav prompts not working.
Other issue I'm having is music reverting to only play on drivers side speakers when using app music (Spotify). When I switch to radio and back to app it seems to fix but annoying having to constantly do this every time. The faders are all set to middle so shouldn't be an issue. If there is a fix for this that would be awesome.
I've tried emailing the seller but never got a reply.
I bought the new firmware and it fixed all issues for me 🙂
