VW GTI 2013 MK6
Quote from chepun on August 11, 2022, 2:00 pmI purchased a Noname RCD330 + 187B for my VW GTI MK6. I went to do the install and had a quick question. After pulling out the old unit there were 3 previous connections, a main hub, a 2 port hub, and a green connecter. When connecting to the new unit the main hub connected, the 2 port hub connected using a provided cable that converted it to 1 hub, but there was no connection for the green connecter. There was also another cable that was provided that I did not use. Does the green connecter need to be connected? What info does it relay?
Thanks
Thanks
