rcd330 with CAN Gateway 1K0 907 530 L
Hi, I have a 2008 golf5 and I would like to buy an RCD 330.
I have seen that I may have battery consumption problems but my gateway is this:
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533 Gateway H07 0052
Revision: H07 01 Serial number: 110408F2013801
Coding: E9807F060002020002
I currently have an RCD510 and have no battery issues.
Can I buy the RCD330 without problem?
Thank you
Michele
PS: The photo is of the current car radio
1K0 907 530 L There is no battery drainage problem. The gateway before L had battery drainage problem. The gateway with two letters behind the 530 also has no battery drainage problem.
