Dual USB ports, keep Front USB, Add Rear USB port, Carplay , Android Auto.
The genuine RCD330 Plus Noname 187B
Android Auto / Carplay /Mirror link
For all Volkswagen PQ car
For Fabia / Octavia / Superb / Yeti etc
Green light Noname 187B or + rear USB or + Wireless Car play dongle.
German, Spanish, Portuguese, Russian, English
Come with Carplay , Mirrorlink, with out android auto.
Noname 280B
Android auto, Carplay. + Rear USB
MQB Volkswagens Original Unit.
USB original installation
FIts Golf 6/7 R/GTI MK6 MK7, Polo C/R/GTI/Plus, EOS/Beetle/Passat CC/Scirocco For RCD330 Plus
Issues with used 187B
Quote from Sidefx on February 9, 2024, 2:58 pmI just recently purchased a used 187B, the serial # is 6RD 035 187B. It came with the rear USB hook up.
One issue I'm having is the USB on the head unit does not work with Carplay. I have use the rear hook up, is this normal?
The biggest complaint is audio or microphone does not work with phone calls. I have deleted the bluetooth on the car and tuned off bluetooth on the headunit. I have software 5614 installed currently but when I try to update my firmware I just get a error that there is no playable files.
FYI the USB on the headunit does flash the light on my USB stick but doesn't appear to load anything.
Quote from Ddren on February 22, 2024, 11:53 amIt is very possible that the USB port is damaged. If you don't want to spend any more money, you can loosen the USB soldering and restore the unit's front USB to working for your phone.
