How to activate the engineering mode of the RCD330 noname 187B
How to activate the engineering mode of the RCD330 noname 187B?
step 1. Connect your car to your computer with Vcds cable.  Twist the car key to the ACC position without igniting the engine. Run the Vcds software, click "select"
setp2, Click  "56-Radio"
step3, Click "Adaptation - 10"
setp4,  Select "Development Test Mode" from the drop down menu
setp5, The initial value in the "new vaule" text box is "0",  click on "up" to the right of it, and the new value is "1". Then click "Save"
setp6, Exit the vcds software and unplug the cable. End the work.
Now you can start the RCD330 PLUS noname 187B and hold down the "setup" button for a long time until the project Engineering menu appears.
Marble and Imran William have reacted to this post.
MarbleImran William
What kind of extra options will I have after activation?
After activation, you can test whether your microphone can work normally, you can know the detailed parameters of your memory and other hardware, and you can see some factory test settings.
Quote from Imran William on March 1, 2021, 11:13 pm
Hi where can i download the Vods software
