Noname 187b RCD330 PLUS Rear USB Refit
Quote from Ddren on April 19, 2020, 1:49 pmSome Volkswagen Jetta and Golf have a USB connector near the ashtray. After some friends installed RCD330 PLUS, this USB was out of action. At the same time, the front USB interface of RCD330 PLUS will look messy. Changing the front USB to the rear USB will look much better.
Please note: If the front USB of the RCD330 PLUS is changed to rear USB, The front USB will only be used for charging, Not working with Carplay and Android auto in the front USB, and it even can not play mp3 songs in a USB flash drive. After welding the soldered rear USB data cable, the front USB interface can resume work.
https://youtu.be/12L_hYQUHbE
