No camera feed from flip badge camera (Golf Mk6)
Hello, I would to fault find this issue.
Does anyone have the pin out for the camera connection plug at that plugs into the badge (the thin camera feed line).  I have tested for voltage and ground on the plug at the back of the car, that seems good however not sure what pins "should have voltage on them"
The head unit thinks that it has a camera for 5 seconds before displaying " The Rear View camera systems is currently not available". I have checked via VCDS and everything seems fine. The badge flips out and stays out for about 10secs.  I am sure the Badge is fine.
I would like to test to see if there is video picture on an external Composite Video monitor before deeming this camera broken, hence the pin out request.
Regards
Im having the same issues with my unit. Any updates on your camera?
