RCD330 & factory reversing camera in 2016 Amarok.
Could anyone who has installed an RCD330 in an Amarok and got the factory reversing camera to function using the required RGB to CVBS cable adapter (see attached) please assist by posting a description of how they did it. Ideally with pictures. Would be much appreciated.
Hi,
Yes I did (eventually), I tried with the adapter and even had a second one sent by the seller as couldn't get it to work.  Then after reading I found out that as mine is a Highline camera (with the moving parking guide lines) it doesn't work with that adapter.
I solved it by getting one of these RCA breakout cables https://www.ebay.co.uk/itm/124748108174 .  On my UK Amarok the controller is above the brake pedal, all I had to do was to then run a RCA cable back to the RCD330 and all worked but no longer have the guide lines.
Hope that helps
Trev
Hi Trev,
So, did you end up needing the RGB to CVBS converter? What do the RCA breakout cables look like? That ebay link is now broken. I have a 2012 Multivan and would like to do something similar.
Thanks for the help!
Sean
