MK6 flip camera black screen
Quote from SneakyTurtle on October 15, 2022, 2:46 amLooking to get some input on this issue I am having. I just got around to installing the camera. Wired it all up and everything seems to work. After about 10-15 minutes, if I place the vehicle in reverse, I can hear flip up camera but there is no longer any image. The camera ground I am using is the same as the flip motor ground. If I briefly turn the car off and back on, the image returns. If I disconnect and reconnect the bullet connector( highlighted in a green box in the attached picture), the image also returns. The #6 fuse tap is connected to the first row of fuses and only has power when ign on.
Was wondering if anyone else ran into this issue.
Uploaded files:- You need to login to have access to uploads.
