187B does not show video of RGB/CVBS adapter
Quote from do78 on June 30, 2024, 9:36 amHello,
I've installed an RGB/CVBS adapter for default camera of skoda superb mk2 (3T). On its inputs:
- Power(red) 12V is present
- Reverse light(yellow) 12V is present if I set DSG to reverse
- GND(black) galvanically checked, it's on ground
If I set ignition to on, and put the car into reverse, then I see video on the output of the AV adapter. I have seen the picture on a random TV screen with composite input.
If I connect the video output of the AV adapter with the BNC male-pinout cable to the 187B, then I see only black picture, and the message 'reverse camera is not available'.
Before finding the right wire on the onboard PCU for 12V, I've seen picture on the 187B, if I connected the yellow to 12V, so I assume that the cabling is fine.
What are your suggestions as next step to troubleshoot this, please?
Hello,
Quote from do78 on June 30, 2024, 12:11 pmIn addition, I've connected an NSTC video signal to the BNC female plug of 187B, and when switched to reverse, I saw the picture as well. In brief, the 187B uses the signal if it comes from a different source than the AV adapter. Is there a way to reconfigure that adapter?
Quote from do78 on June 30, 2024, 3:29 pmI keep talking to myself here, I had to drive away, and after a while I started having picture from the camera. It's not obvious if it keeps working, or what has happened.
