Flip Camera “ The Rear View Camera system is currently not available” - HELP
Hi, have installed the Flip Camera and everything is wired as it should and once I engage Reverse the flip camera opens but I get the message on the RCD 330 saying “The Rear View camera system is currently not available.
I have enabled the Rear Camera on my OBD 11 so not sure what else I need to do.
here’s a photo of my original harness but I also have the steering wheel controls harness plugged into that.
here’s the steering wheel harness plugged in the RCD 330 with the MIB adaptor
thats the original blue plug on the harness
the wiring for this badge is different to the ones I’ve seen online as there’s a single Blue wire which is tapped on with the Reverse Light so there’s no CAN cables to connect up at the head unit side.
I have a solid Ground connection on a screw in the Fuse Box and getting the correct 12v at both sides.
this is the RCD 330 I have if it helps
can anyone help please?
