Golf 5 backup camera installation
I've installed a flip camera (with OBD support 🙁 ) on my golf5 and found a strange behavior.
the first time it lanches (- acc connected) it works, but says "no can".
if I switched the ignition off and remove the key, after some period of time turn the car on again, it stops working.
I need to switch "-" acc off wait a while, switch it on. and it works with "no can" message and again after key removed from the ignition, it stops working
I have PQ quadlock, but looks like the camera required MIB.
maybe I'm selected the wrong fuse to connect?
I've inserted power cable into  16 fuse place (maybe wrong place?)
all features, like flip and rear door opening, is working fine.
maybe someone know how to resolve this.
George Hatch has reacted to this post.
George Hatch
You'd better provide some pictures, it may be easier to help you solve this problem.
First of all, if the screen of your head unit displays "No CAN", which is usually liked, it means that your reversing camera supports dynamic trajectory and needs to be connected to CANBUS. In most cases, you can still get images when reversing. But there is no hint of dynamic trajectory.
If the image occasionally disappears when you are reversing, you need to check ACC 12V+.
Yes,  you were right. I've re-installed all power cables and all start working expect small bug.
when I turn the ignition on, the camera works ok (there still message no can). But after a short ride (5 min approx.) when I'm trying to part camera wont work.
I've got an alert "camera not found".
I need to switch the ignition off, then on again and it starts working.
no idea how to resolve this.
Is your head unit RCD330 PLUS?
Can you provide the following link to purchase your camera?
I need to confirm your product introduction.
Does your camera need to be connected to the reversing light?
RCD330 PLUS, bought in the local store (if this means no help then ok)
my camera connected to reversing lights (flip camera)
You may directly use the reversing lights to power the reversing camera, which is unstable power supply. You'd better install a delay box. You’d better provide an overall picture of your flip camera, including cables. I will know how to solve it.
This is show my camera looks like. Power cable (on picture) connected to 12+ and to revers lights.
Obd cable (on picture) connected to quadlock and to acc 12+
rear view
This camera does not need to be connected to a reversing light. First of all, you must find the correct ACC12V+ in the fuse box, and then you need to connect CANBUS+ and CANBUS-, otherwise it will not work properly. CANBUS+ and CANBUS- need to break the skin of the wire and leak the copper wire in the wire, otherwise it is easy to falsely connect .  In addition, you must confirm whether your car has an ESP function. Without this camera, it will not work properly.
